A unique GOLF R in Tunisia
  • A unique GOLF R in Tunisia
    In this article i am gonna talk about the Mk7.5 VW GOLF R (or as some call it the face lifted MK7 GOLF R),
    particularly, my friend's Mk7.5 GOLF R, but before we get to that let's start with a little introduction for
    those who never heard of the R model in Golfs.
    Note: alot of people think that '' R-line " and '' R" are the same thing.
    They're not. R-line is just a trim, it's just a normal golf with some bits and pieces in the outside and inside to make it look a little sportier, but power output is just like any other normal Golf.
    In the seventh generation of the VW Golf's line up, we find normal models,
    either with petrol or diesel engines or an all electric version called ''e-golf".
    Then, we get to the sporty versions. We begin with the Golf GTE
    which is a plug-in hybrid driven by two power sources: a 1.4-litre (148 hp) TSI direct-injection petrol engine and a (102 hp) electric motor. Together, they combine to produce power of ( 201 hp) and 350 N.m of torque.
    the Golf GTE can accelerate from 0-100 km/h in 7.6 seconds and on to a top speed of 215 km/h.
    Then we have the GTD. It is powered by a 2.0-litre turbocharged common rail diesel engine
    with 181 HP and a maximum torque of 380 N⋅m available
    from 1,750 RPM. 0 to 100 km/h takes 7.5 seconds and top speed is 227 km/h.
    Then we get to the famous GTI. I am not going to get into details but the power output varies from 217 HP to 306 HP.
    I am just going to talk about the basic GTI.
    It has a 2.0-litre turbocharged direct-injection petrol engine (TSI) with 217 HP and 350 N.m of torque.
    It does 0-100 km/h in 6.5 seconds and goes to a top speed of 250 km/h.
    Now we talk about the R. You see, all the previous models are FWD (front wheel drive), the R on the other hand is AWD (all wheel drive). It uses the fifth-generation Haldex 4MOTION four-wheel drive system. Under low loads or when coasting, the rear axle is decoupled, helping to reduce fuel consumption. Drive to the rear axle can be engaged in fractions of a second via the Haldex coupling, which is actuated by an electro-hydraulic pump. Up to 50 percent of power can be transferred to the rear axle. A brake actuated, XDS+ system mimics a limited-slip differential by applying the brakes to the wheel with the least traction, this is on both the front and rear axles.
    The MK7 R's 2.0 TSI engine makes 296 HP and 380 N.m of torque from 1,800 to 5,500 RPM. 0-100 km/h takes 5.1 or 4.9 seconds with optional DSG gearbox. The top speed is electronically limited to 249 km/h.
    The MK7.5 R makes 10 more HP but all the other numbers remain the same. Some esthetic changes were made as well.
    My friend's MK7.5 R is a little bit special. It's been fitted with an Eventuri Intake, a new radiator, a new turbo inlet pipe, a decat, new spark plugs, APR ignition coils and a stage 2 software. Now it makes 430HP and 550N.m of torque at the wheels (as shown
    in the dyno graph below) which makes it very unique in Tunisia.​ All the work was done by a tuning workshop in Germany.
    اضغط على الصورة لعرض أكبر.   الإسم:	40fc4b8b-6246-41ed-a8eb-92a5c33b06c4.jpg  مشاهدات:	63  الحجم:	136.5 KB  الهوية:	6995
    اضغط على الصورة لعرض أكبر.   الإسم:	79406517-14f8-4e99-993d-deffb7a2211f.jpg  مشاهدات:	73  الحجم:	143.5 KB  الهوية:	6994
    اضغط على الصورة لعرض أكبر.   الإسم:	2f94ed3e-4100-4784-b370-a72ef6adcae6.jpg  مشاهدات:	63  الحجم:	93.7 KB  الهوية:	6996
    اضغط على الصورة لعرض أكبر.   الإسم:	56349f98-e85a-42fd-8019-931bfbe6a133.jpg  مشاهدات:	63  الحجم:	84.8 KB  الهوية:	6997
    اضغط على الصورة لعرض أكبر.   الإسم:	73e3f135-3228-4756-806f-4320466786d2.jpg  مشاهدات:	63  الحجم:	78.4 KB  الهوية:	6999​​
    اضغط على الصورة لعرض أكبر.   الإسم:	6bb23c2f-7bd9-48e7-a310-cc8ecaf30d18.jpg  مشاهدات:	63  الحجم:	67.8 KB  الهوية:	6998​
    اضغط على الصورة لعرض أكبر.   الإسم:	33fa26ba-082e-4e24-b6d8-b5178e4adaaa.jpg  مشاهدات:	64  الحجم:	62.0 KB  الهوية:	7000
    Here's a short clip showing this car's performance. In the video i am doing a little demonstration on how to engage Launch Control.
    https://m.facebook.com/story.php?story_fbid=pfbid02E2EhDnXU1DVowoaWhXqCj4 cF4VqcUHDrxNhEzfwZEZN4qb32Ey5HSv2J7eLR3rK2l&id=100 002158237872&mibextid=Nif5oz
    منشور يظهر متع محترفين لكن شكون باش يقراه باللغة الانجليزية ؟
    على كل هذه ترجمة جوجل منقولة حرفيا :
    في هذه المقالة سأتحدث عن Mk7.5 VW GOLF R (أو كما يسميها البعض ، الوجه مرفوع MK7 GOLF R) ، على وجه الخصوص ،
    Mk7.5 GOLF R من صديقي ، ولكن قبل أن نصل إلى ذلك ، فلنبدأ بالقليل مقدمة لمن لم يسمعوا عن طراز R في لعبة الجولف.
    ملاحظة: يعتقد الكثير من الناس أن "R-line" و "R" هما نفس الشيء. هم ليسوا كذلك. R-line هي مجرد قطعة ،
    إنها مجرد لعبة غولف عادية مع بعض القطع والقطع في الخارج والداخل لجعلها تبدو رياضية قليلاً ، لكن خرج الطاقة يشبه أي لعبة غولف عادية أخرى.
    في الجيل السابع من تشكيلة VW Golf ، نجد موديلات عادية ، إما بمحركات بنزين أو ديزل أو نسخة كهربائية بالكامل تسمى "e-golf".
    ثم نصل إلى الإصدارات الرياضية. نبدأ مع Golf GTE وهي سيارة هجينة تعمل بالكهرباء بواسطة مصدرين للطاقة:
    محرك بنزين TSI بالحقن المباشر 1.4 لتر (148 حصان) ومحرك كهربائي (102 حصان). يتحدان معًا لإنتاج قوة (201 حصان) و 350 نيوتن متر من عزم الدوران.
    يمكن لسيارة Golf GTE أن تتسارع من 0-100 كم / ساعة في 7.6 ثانية وتصل سرعتها القصوى إلى 215 كم / ساعة.
    ثم لدينا GTD. وهي مزودة بمحرك ديزل بسعة 2.0 ليتر مزود بشاحن توربيني بقوة 181 حصان
    وعزم دوران أقصى يبلغ 380 نيوتن متر من 1750 دورة في الدقيقة. من 0 إلى 100 كم / ساعة تستغرق 7.5 ثانية وتبلغ السرعة القصوى 227 كم / ساعة.
    ثم نصل إلى سيارة GTI الشهيرة. لن أخوض في التفاصيل لكن خرج الطاقة يختلف من 217 حصانًا إلى 306 حصانًا.
    سأتحدث فقط عن سيارة GTI الأساسية.
    بمحرك بنزين توربيني سعة 2.0 لتر يعمل بالحقن المباشر (TSI) بقوة 217 حصان و 350 نيوتن متر من عزم الدوران.
    تتسارع من 0 إلى 100 كم / ساعة في 6.5 ثانية وتصل سرعتها القصوى إلى 250 كم / ساعة.
    الآن نتحدث عن R. كما ترى ، جميع الطرز السابقة هي FWD (الدفع بالعجلات الأمامية) ،
    أما R من ناحية أخرى فهي AWD (الدفع الرباعي). تستخدم نظام الدفع الرباعي
    من الجيل الخامس Haldex 4MOTION. تحت الأحمال المنخفضة أو عند الانطلاق ، يتم فصل المحور الخلفي ،
    مما يساعد على تقليل استهلاك الوقود. يمكن تعشيق القيادة إلى المحور الخلفي في أجزاء من الثانية عبر وصلة Haldex ،
    والتي يتم تشغيلها بواسطة مضخة كهروهيدروليكية. يمكن نقل ما يصل إلى 50 بالمائة من الطاقة إلى المحور الخلفي.
    يعمل نظام XDS + على الفرامل ، وهو يحاكي ترسًا تفاضليًا محدود الانزلاق من خلال الضغط على المكابح على العجلة بأقل قوة جر ، وهذا على المحورين الأمامي والخلفي.
    ينتج محرك MK7 R 2.0 TSI قوة 296 حصان و 380 نيوتن متر من عزم الدوران من 1800 إلى 5500 دورة في الدقيقة.
    من 0 إلى 100 كم / ساعة تستغرق 5.1 أو 4.9 ثانية مع علبة تروس DSG الاختيارية. السرعة القصوى محدودة إلكترونيًا بـ 249 كم / ساعة.
    ينتج MK7.5 R 10 نقاط صحة إضافية ولكن تظل جميع الأرقام الأخرى كما هي. تم إجراء بعض التغييرات الجمالية أيضًا.
    إن جهاز MK7.5 R الخاص بصديقي مميز بعض الشيء. لقد تم تزويده بمدخل Eventuri ، ومبرد جديد ،
    وأنبوب مدخل توربو جديد ، و decat ، وشمعات شرارة جديدة ، وملفات اشتعال APR ،
    وبرنامج المرحلة 2. الآن تنتج 430 حصانًا و 550 نيوتن متر من عزم الدوران على العجلات (كما هو موضح في الرسم البياني الدينو أدناه)
    مما يجعلها فريدة جدًا في تونس. تم تنفيذ جميع الأعمال بواسطة ورشة ضبط في ألمانيا​
    تنجم تستعمل إيقونة إضافة فيديو في شريط الأدوات عند كتابة المقال، تكون النتيجة هكة:
      التصويرة متع كيت eventuri كانت في ألمانيا ظاهر من pavé متع الرصيف
      لقيت رابط الشركة هذه و رابط الكيت الي ركب في السيارة
      الي يحب يحل نيابة متع تونينغ كيما الي خدمت الحدمة متع الغولف كان موش غالط
      يتصل بالشركة هذه
      عندها عروض لفتح فروع
      Dynojet is the world leader in performance enhancement products for motorcycles and cars. Push the limit of your vehicle with our powersports vehicle parts.
      موضوع مميز ينجم يكون فيه برشة حديث
